NP205 shifter bolt broken...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ddragggon, Jun 28, 2001.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    in my new suburban ( yeah, not a blazer, but this forum is a little more active then the suburban one) the shift linkage is not connected to the shifter stick. the guy I got it from said that it was a bolt that was proken off, and that its a simple matter of backing the bolt out, and then installing a new one through the stick.
    is this a simple matter? will I be able to reach it without dropping the T case? will it be easier to get it from the top or the bottom, the side, while standing on my head, balancing a jug of water on my foot, etc...
    thankyou in advance,
    -Rich
    1977 C20 suburban
    454/400 trailering Special
    1973 K20 suburban
    350/350/np205
    Atlantic 442 Steam locomotive
    Daisy Mt Railroad
  2. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    This happend to me right after installing my t-case.
    I did it while it was in the blazer, but i have the removable cover in the inside of the cab.
    Just get you a good small angle drill and also a good (preferably a new one) drill bit and a good easy out.
    Make a small pilot hole then use what ever size bit the easy out says to use. I got lucky and mine came right out.
    'Good luck
    Blazin72
    Blazin 72
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How do you have a C20 4x4 Suburban? Did someone put it on a 4wd frame?
    Tim
  4. Ddragggon
    Apr 25, 2001
    2,657
    <blockquote><font size=1>In reply to:</font><hr>
    <hr></blockquote>
    nope, its just a really beefy 2wd suburban, that I take/took anywhere, and everywhere thats wide enough to squeeze it through. prolly not the best of ideas, but I always went with a friend ( he has a 76 C10) so that if one of us got stuck, it'd be a metter of getting the towstrap out, and finding a different line. the 73 K20 is a brand new addition ( almost 36 hours old!) and I'm just getting used to having it around. body panel repairs, priming, paint, and windows are the first order of business on the K20.
    -Rich
    1977 C20 suburban
    1973 K20 suburban
    350/350/np205
    Daisy Mt Railroad
  5. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    You should have the removable cover, so it would probably be easiest to get at it from above (inside the cab). I just picked up a new transfer case shifter bolt from Chevy for my '73 K20 Suburban w/NP205; same as yours. Part number, if you're interested, is GM #14009313. I paid $17.75.
    Robb
    '73 GMC Suburban - 502DFI
    <A target="_blank" HREF=http://community.webshots.com/user/robbrj>http://community.webshots.com/user/robbrj</A>
  6. Ddragggon
    Apr 25, 2001
    2,657
    you have a 502? &lt;drool&gt; one of these years when I'm loaded with Cashmoney.... thanx for the part number info, I'll give them a call, and go pick one up on the way home. I dunno if I have the full removable tranny hump, but after getting a look at the bolts position on the case, I'm really hoping I do....
    -Rich
    1977 C20 suburban
    1973 K20 suburban
    350/350/np205
    Daisy Mt Railroad
  7. 502Burban
    Jun 8, 2001
    379
    Southern California
    Glad to help.
    I hear you regarding the cash money.[​IMG] Hopefully, I'll find some more soon so that I can finally hear that 502 start! Good luck with getting at the bolt.[​IMG]
    Robb
