NP205 shifter is it too tall?
Discussion in 'The Garage' started by wazzabie, Aug 26, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    I removed the NP203 and put in a NP205. The shifter for the NP205 is s tall compared to the NP203. I'm affarid that someone will bumb into it and it will go out of gear. It also has a long throw. I took it from a 72 and put it in a 78. Any one cut down the NP205 shifter?
  2. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    my old 205 shifter took alot of effort to shift it, some one would have had to kick it real hard to shift it accidentally.
    never cut one down, but if i were, I would chop it below the boot, remove "x" numer of inches from the top half, and reweld it so all the evidence would be concealed. IIRC you would have to turn the shaft down skinnier if you just cut off the top and tried to rethread it. lot more work IMO
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    find a lever from a 73-newer 205. levers changed with body style
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Measure your lever before you cut it because mine is too short. I'll trade you if so. Mine measures roughly 14" from center of pivot bolt to top of threads.
  5. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Can you provide more details about the lever changing with body styles?
  6. dyeager535
    26,980
    The lever that came out of the '91 1 ton I took parts off of is different in design than the mid 70's one I replaced it with. (mainly due to the fact that the adapter was longer, placing the shifter pivot bolt further back than earlier)
    If the distance from the floor pan to the shifter "pivot" changed, then you can make a pretty educated guess that the shifter itself chenged in at least length.
