NP205 shifter tightening...use plain washers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Mar 26, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have my tranny tunnel off so I can POR it. I am looking at the 205 shifter right where it attaches to the tcase adaptor (205/465).
    It is just a big bolt, like 7/8" bolt that the shifter pivots on. My shifter can rock left to right right at this point.
    I don't see why I can't remove the bolt and use some flat washers to take up the space.
    I seem to remember someone posting that there was something better to use than plan washers, but I don't remember what.
    -- Mike
  2. dyeager535
    26,980
    I had a plain washer in mine, and the stupid thing kept working itself loose. Even with the bolt "bottoming out" like its supposed to, the bolt would work loose. There is supposed to be a pretty weak "wave washer" underneath the bolt head to keep SOME tension on it. Without it, I have a slight rattle at cruise.
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    there's some plastic bushings that go in there.....
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My 205 came out of a 1980 1-ton truck. It has a wave washer under the head of the bolt to keep the shifter from rattling. You might be able to get the washer from GM still.
  5. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Mine needed tightening, too, but I found a greaseable bolt at a junkyard from a 205. Now I just keep it pumped full of grease and it stays rattle free for a while. I think there's supposed to be some plastic bushings in there somewhere, but mine is missing those of course.
    Will
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The bolt on mine is also greasable. It has a zerk in the head of the bolt. There isn't any plastic in there on mine though. Just the wave washer.
  7. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I found a round rubber gasket that is just bigger than the diameter of the part that the shifter rides on. Its about 1/8' thick and seems to have fixed the rattle. The shifter is still real easy to move and the bolt hasnt backed off at all. I couldnt find a wavy washer nor did I want to go to a dealership to get it, and I had this sitting around and its worked great.
