NP205 slip yoke eliminator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Goose, Aug 15, 2006.
  1. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I have a '86 K30 with a 205 and rear slip yoke.
    I also have a non-slip yoke 205 from a 77.
    What can be done to make the 86 non slip yoke and the 77 a slip yoke??
    How much disassembly is involved?
    thanks
  2. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    I would think it would be easier to just swap the 205's as a whole between trucks. That wat their is no disassembly required.
  3. Goose
    1,127
    Yes, but the slip yoke one is a round pattern 205 and the other is a figure 8.
  4. dyeager535
    26,976
    If it's JUST the output shaft/housing that needs swapped, with both of them on the ground, you can swap them doing essentially nothing else but pulling the output shaft housing off, and pulling the output shaft.
    I've swapped an output shaft before ('91) but it was non-slip for non-slip. I don't know if there are any internal differences, but if I remember my parts manual correctly, there IS a difference in the cases (same year ones) between autolocking and manual hubs. I never spent the time to see which parts were different, but I do know the parts diagrams were annotated like that.
  5. Goose
    1,127
    Hmmm,
    I guess once I take them out of their respective trucks and apart I'll know for sure.
  6. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Unbolt one and bolt the other in it's place.Takes the same bearing and everything.The hardest part is the needle bearing's that go in the back of the shaft.It can be done in the truck,but you better pack the rollers in grease before you try to put it in.I have done it many times and have sold a bunch of them,
    Like right here.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130017556149
  7. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Dorian, the difference you refer to applies only to the front output or 4x4 engagement syncronizer ring; most have a ring, but the auto-locking hub models had a clutch system. Rgfparts had one for sale on ebay a while back.
    In short, it doesn't apply to this thread's question.
    All he needs is some grease to hold the needle bearings in place when he puts the shafts back in the case.
    Jimbo
    edit; too slow
    edit again: "rgfparts" is an excellent source for 205 parts, when he has time to list them on ebay.
  8. 1-tonmudder
    Apr 24, 2005
    3,052
    That's the way mine is.
  9. Goose
    1,127
    Sounds easy then. Thanks a ton.
