NP205 Swap In
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82 K10 Power, Feb 11, 2002.
  1. 82 K10 Power
    82 K10 Power Registered Member
    Dec 7, 2001
    6
    My current set up is TH350 with a 208, I am about to swap in a 205, should this bolt up fine? Is there anything I should look for? Also, the 205 I just picked up has been sitting in a guys garage for about 2 years, its a 1975, should do anything to it before installing it? Maybe a rebiuld? He said it works fine but I am not really sure what to be looking for.
    82 Chevy K10- 350 4-bolt, TH350, NP208 (Soon to go), 10-bolt rear (soon to go)
  2. dyeager535
    26,977
    Shifters are entirely different. Haven't yet figured out how I am going to seal up the hole in the floor, since your 208 shifter is bolted to the tranny hump.
    If you can find one, use a bolt in tranny hump from an earlier truck, with 205 or perhaps 203. Your transmission hump should be bolted in.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. 82 K10 Power
    Dec 7, 2001
    6
    From your post I am guessing that I will need to hit the bone yard to find another shifter also? Or is an adapter that will allow me to use the original one?
  4. dyeager535
    26,977
    205 shifter is a handle that is bolted to the tranny/t-case adapter. NP208 shifter is entirely different. Boneyard would be my choice, and I'd pull the shifter tunnel out of the same truck.
    Dorian
  5. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    You need to make sure the floor tunnel is the same lenght as the one you have .When i changed mine out i tried to use the tunnel from the donor truck and it was to short .
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
  6. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    CALL AVALA. ENG. THEY HAVE A TWIN STICK SET UP FOR THIS. I HAD ONE IN MY 205 TO 700R4 SET UP IT WORKS GREAT.
  7. th350s that came with 208s have a long output shaft and will not work with your 205. you will have to swap in a short output shaft that was used in th350s that had 203s or 205s. or just look for another trannie in good shape that had a 203 or 205.
    <font color=blue>You think you're excited, feel my nipples!
    </font color=blue>
  8. 82 K10 Power
    Dec 7, 2001
    6
    Have a number or web address?
  9. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
