NP205 SYE
Discussion in 'The Garage' started by txfireman110, Jan 27, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Found all kinds of posts about a 208 SYE, but nothing for 205 /forums/images/graemlins/doah.gifIs there such a thing???Who makes them??? Why can't I find anything on a 205 SYE?
    Thanks /forums/images/graemlins/thumb.gif
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    What is SYE? Never heard of it. Sorry?!? /forums/images/graemlins/1zhelp.gif
    Kris
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    They came stock with the yoke on the output as well as the slip setup. You can try trading your 205 for a yoke version or rob the parts off of one. I just traded mine at the junkyard.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    He is referring to a Slip Yoke Eliminator kit. As far as I know, they are not offered aftermarket for reasons below.
    The NP205 came factory with both slip style and non slip style rear output shafts. Since these parts are a factory item, you might look at local junkyards or in the for sale boards if interested in purchasing a used setup.
    What you will need:
    Rear Output shaft, bearings, output housings (1 steel with 1 aluminum bearing retainer), yoke, seal and retaining nut.
    Most people offer this in "kit" form when selling on these boards.
    I could find one for you if you want. Expect to pay around $100 plus shipping for this item when shopping around. /forums/images/graemlins/thumb.gif
  5. mud390
    Oct 31, 2002
    1,210
    Thanks for the info! I feel enlightened now! I learned my 1 new thing for the day. Can I go home now? /forums/images/graemlins/deal.gif
    Kris
  6. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Thanks Mudzer,
    I may be back in touch with you, but I'll try to find one local first. I might even have one and not know it. I am buying a K30 that has a 205, but I didn't even look cause I didn't know about them!!
  7. Mudzer
    3,639
    Missouri
    Chances are if it has an NP205, being in a K30, it might very well be a non slip. /forums/images/graemlins/thumb.gif
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yeah, gotta change the parts from a fixed yoke kit. I have to do the same. I Put an add in the "parts wanted" section and got a bunch of replies, I have all the parts, just need it to warm up a bit! /forums/images/graemlins/thumb.gif
  9. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Mine is an 85 K3500 /forums/images/graemlins/truck.gif and it has the slip yoke /forums/images/graemlins/confused.gif
  10. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    <y 80K5 has a slip yoke too /forums/images/graemlins/angryfire.gif
    I'm trying to find a non slip as well
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Contact this guy, he should have everything you NEED.
    doctor4x4@hotmail.com
    He is also a member here
    doctor4x4. PM him. I know he's got your parts.
  12. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Thanks for the prop's there baBlazer73
    Ill make sure ya get your comission check :-)
    Yea i only have 1 set up left t sell so Mudzer is a good guy also and says he can get em and the price is the same so i say save a little on shipping if he is closer 2 ya
    and
    for what its worth in my experience
    1980 and up are all slip yoke
    and 1979 and down are fixed
    Stick shifts have a better chance of being fixed then a auto
    but ya never know what outher s have done to rig before you seen it
  13. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Stick shifts have a better chance of being fixed then a auto but ya never know what outher s have done to rig before you seen it
    Mine follows doc's guidelines above with a fixed yoke. I have an extra yoke if you come up short there for some reason. When I replaced the nut (and got the extra yoke) someone told me the 203 yokes and nuts were the same. Anyone know about that and if more parts are the same? If so, I have a junked 203 that I can pull whatever you need from.
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    for what its worth in my experience 1980 and up are all slip yoke and 1979 and down are fixed
    My '91 is fixed yoke - and stick shift. The citeria I've come to know is wether the vehicle has a two-piece driveshaft (& support bearing) or not. One-piece gets the slip, two-piece gets the fixed.
    For '80 newer, you will find up to 131.5" wheelbase (reg cab longbox) gets a one-piece rear shaft; and 135.5" wheelbase (cab & chassis reg cab) and longer gets a two-piece shaft. Tranny type doesn't seem to matter.
