np205 tcase fluid in th350
Discussion in 'The Garage' started by wazzabie, Aug 26, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    Any one had any problems with tcase fluid getting into the tranny via bad seals? This is a big concern for me.
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Have you??
    With the preasure the trans makes I don't think it can go that way. Now ATF in the 205 can and does happen. Just make sure you have a good seal and you'll be fine.
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    you do not want gear oil in the auto tranny.
  4. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    Never had gear oil in the tranny but when I picked up my NP205 I was surprised to find ATF fluid in it. I pulled it from a 72 for my 78. I guess it doesn;t hurt to run ATF fluid and I figure it would prevent any problems if the fluids mixed.
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    some people dont know what goes in so any oil does at the time. that tcase that old should be gear oil. and just change the seals while out. you dont want to swap it out again any time soon as its big and heavy.
  6. big_o_blazer
    big_o_blazer Registered Member
    Jul 13, 2005
    13
    north carolina
    i wouldnt worry
    here in the army thats what we put in the HMMWV's transmission and tranfers is dextron 3 (ATF) works just fine i dont know what kinda transfer they use but ive never seen a problem cause of the ATF
  7. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Never seen that happen, usually the other way round, but you might want to check the vents on your transfer case. May be plugged allowing pressure to build, pushing gear lube into tranny.
  8. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    Good point Rusty Parts. Also GM calls for gear oil in the np205.
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    There is nothing wrong with running ATF in a 205. It was factory spec for some years.
  10. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    Interesting... do you know what year ATF was called for?
  11. sweetk30
    Nov 1, 2004
    25,539
    538
    all 205's same in side . so atf or gear oil as you wish. just run it like you would and check to make sure case isnt over heating . if so might want to run gear oil.
