Np205-Th350
Discussion in 'The Garage' started by adamforsythe, Aug 24, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I know to mate up a Th350 and a Np205 I need to shortin the tail shaft. How would I go by doing this? Do I have to drop the tranny and rip all the gears out to get to the tail shaft? When I had the tranny out I really did not look at the tail shaft. So I don't know if I can remove it from the back. I really don't want to take the truck to the shop because I want to say I built the truck up 100% myself and with the help of a few friends. :D Plus not taking the truck to the shop will save me MAD $$$$$$$$$$$$. :bow: :D :D :D
    Adam
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the 350 tranny with the right adapter will bolt right up. If you mean the 700r4 you can just get a spacer or you can put in a special output shaft which is about $150 from advanced adapters
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Th350s came with NP205s. I'm not sure what your asking. If you've got a th350 adaptor, coupler, and a 27 spline NP205 its direct bolt in. ?????
  4. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    I found a NP205 mated to a TH350 from a 72 K5 and it fit perfectly with my TH350 on the 78 K5. I did not need to tear into my tranny. Be sure to put new seals in the adapter cause I think a bad seal could get t-case gear fluid into the tranny. Some do not run gear oil in the t-case for this reason. I was able to pull all the parts from a 72 K5 with low millage for onlt $250 bucks. Only two problems. I had to bend the shift linkage. The rail mount from the 72 K5 was to short for the 78. Maybe someone knows how to fix this.
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Right now I have a Np208 mated with my TH350 and I thought to bolt on a NP205 the tailshaft has to be shorter.
    Am I wrong?
    Adam
  6. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    stock I had a np203 to the th350. Maybe some experts can chime in or the answer could be found searching the forum.
  7. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    From the research I've done in the past 2 weeks I think you are wrong. You will need the TH350/NP205 adapter and a 27 spline coupler. This assumes the NP205 you have came from behind a TH350.
    BTW, if you do go ahead w/ the swap I'm in the market for a TH350/NP208 adaptor. Let me know if you are intrested in selling it.
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i do think you are going to have to do some mods if you had a 208 behind a 350 tranny. You can go two different ways you could get an output shaft from a older 350 trany and swap it in or you could get a spacer so you do not have to tear the tranny down or even take the tranny out of the truck.
