NP205 to 700R4
Discussion in 'The Garage' started by K5dreamer, Aug 20, 2006.
  1. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    Hey all, im lookin to swap a 4x4 700R4 into a 72 blazer with the NP205 transfer case to get the overdrive gear. anyone know what imma need to do that swap? do they bolt right up or am i going to need some sort of adapter?
    thanks in advance for any tips.
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    you'll need a factory th350-to-np205 adapter + the ~2" spacer. I used one with my 700 for years, worked great. They are around $60. I forget the part #, but if you search, its out there.
    j
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You might check with advance adapters: http://www.advanceadapters.com/ As far as I know there was never a 700 to 205 from the factory.
    Ooop, looks like Jek answered your question.
  4. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    Which 205 do you need?
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Would need to be a 27 spline 205 from behind a TH350.
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, what he said... sorry I forgot about that part. ;) On the plus side, th350-version 205s are common and cheap. :thumb:
    j
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    If you buy a klune-v underdrive it will work as the adapter and give you another gear to choose. They are expensive though. But any input spline to any output spline is nice with a choice of ratios.
  8. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    ok well the truck already has the th350 and np205 transfer case, so i guess i just gotta find that 2in spacer.
    second question, does this swap create any drivetrain angle problems or driveshaft length issues??
    i plan on putting a 4in suspension lift on the truck sometime down the road, would that complicate the swap?
    thanks again
  9. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    There are two options to adapt, the 2 inch spacer mentioned (usually found on 80s 350/208 combos) or get a short output shaft for the 700r4.
    This swap (especially if you use the spacer) will actually help the front drive line because it will be longer and will keep the u-joint angles liveable. I would recommend using a CV on the rear driveshaft to keep the angles and vibrations down to a minimum.
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You will need to lengthen the front shaft and shorten the rear shaft. The 700R4 is 1 7/8" longer than a TH350 and then you'll be adding a 2" spacer so you're going to be about 4" longer than your existing TH350/205. Driveshaft angle on the rear will be a problem that you will need to address right away or else you'll be getting a bad vibe. I would definately run a CV rear shaft.
  11. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    good to know guys, thanks.
    you mention the CV rear shaft link. is that something i can just google, or do you reccomend a specific source for that part? also is it hard to install? i have an air compressor and probly most automotive tools nessesary, however i do not have a welder, and am not really experienced at the task. would this CV joint install be a bolt in process?
  12. bigblock72
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    You will have to have the driveshaft built the correct length with a CV (basicly two u-joints right next to each other allows higher operating angles, most front driveshafts use a cv on the front shaft on the t-case end.) You will have to change the yoke on the transfer case to correspond with the CV. So basicly once the shaft is built it is a simple bolt on deal.
