NP205 vent extension?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Jul 24, 2000.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    The vent on my np205 is capped with a loose fitting metal cap. Does anyone know if I can just pry this cap off to add an extended vent line, or should I replace the fitting? Is this a press fit or screw in fitting? The transfer case is installed in the truck, so access is fairly limited.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    You can do either, I pryed the cap off mine, did not like the look of what was left sticking out, pryed out the rest and went to the parts store nad put in a plastic T, it was a little big, so I did some sanding on it and forced it in. Then I connected the tranny vent to one end of the T and the other I ran up to the fire wall.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
