NP205 vent location???
Discussion in 'The Garage' started by Beast388, Mar 14, 2005.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am in the process of getting my truck ready for a run on the 26th. After seeing the location with my own eyes, there is a good chance I may be up to the frame in the soupy goo.:doah:
    So anyways, I am extending the vent tubes for the TH350, NP205 and both axles. Does anybody have a pic of the location of the vent on an NP205?
    I have felt around on top of the t-case and could not feel a vent, but the grime on top could be hiding it.
    Anybody have a good pic?
    Thanks in advance for the help.:D
  2. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    its on the rear output shaft housing that bolts to the csae housing little stub, and some have a metal cap crimped on them.
  3. dyeager535
    26,981
    Correct. Ones I've seen are all press in vents, metal cap. As installed on the truck, you have to feel around the top of the cast iron portion of the output shaft housing.
    Drill if necessary, definitely tap is how I'd get a "good" vent in there.
  4. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    What they said...Also, in stock form the hole is 3/8" dia smooth wall. To tap it to 1/4 NPT you will need to drill to 7/16". I just did this last night:D The hole is fairly shallow also, so a normal tap will be about one turn less than basic measurement on the NPT tapped hole, just FYI. Still works fine.
