NP205 with PTO
Discussion in 'The Garage' started by clarkjw24, Feb 14, 2007.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Hey guys. I've searched but how much does a 205 with the side pto go for?
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i have no idea but correct me if im wrong but didnt they come divorced in dodge pickup...isnt that the most comon place to find them???
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Yeah you could get a divorced case form a dodge or international. Reason I'm asking is I've never had one but I've got one now I need to sell for someone. I've never priced them or even looked for one so I'm completely stumped on what they're worth with the pto.
  4. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    All 205's came with the PTO provision on the side...
    Rene
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    check a big truck place, lots of dump trucks use the same part. it should be a muncie style pto pump. never seen anyone mount a chelsea style to a small pto provision.
  6. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
  7. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    I was told if i wanted to run a hydro winch I would need one of these is this true and does anyone know what one I would need for a 203 / 205 doubler?
  8. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    IMHO you would be better off with a belt driven hydraulic pump than a PTO driven pump. In either case you have to have your engine running in order to run the winch but with the belt driven pump you can put power to the axles without turning the tires to assist the winch. With the PTO driven pump you can either put the t-case in neutral to run the winch, in which case you won't be able to supply power to the tires or you can put the t-case in gear and you will have to spin the tires in order for the pump to turn.
    I ran a PTO winch for close to 20 years and it was great for pulling others or using the winch to do other work but for self recovery it could be somewhat of a pain for the same reasons that I listed above. I finally sold the rig but kept the winch and I may do something with it but I bought an electric winch as the primary winch for my next buggy.
    Gus
  9. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    yea i believe also that all np205s came with the pto.....if your going to run a hydraulic winch id run it off of your PS pump, that is the simplest way...also i dont want to hijack your thread, but what entails hooking up to the pto part of the 205, ive never seen it done i just know that there is a block off plate on it.......
