NP205 wont disengage
Discussion in 'The Garage' started by Citizen Rider, Sep 19, 2006.
  1. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    My blazer is having all sorts of trouble and it never seems to end...
    I put an np205 in behind my th350 a couple months ago and its barely been driven since.
    today i went out and messed with it some and drove it down the gravel some. Will not disengage out of 4hi. I put it in 2hi and front still spins(i have no front shaft at the time) so i grabbed a good size stick and stuck it through my floor hole and it snapped quickly.
    If i can get the engine running right and make sure my tranny is still good(i cant keep a tranny for the life of me) i will be ordering a twinstick to end the guess work of the shifter and use of front only.
    Any ideas??
  2. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    205 won't disengage
    mine spun too with no drive-line on it.But once you have a one in it should stop spinning
  3. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Thanks for the reply. Hopefully that is true. I should have a shaft built next week for it. we shall see.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I find the detent between 2HI and 4HI isn't very positive. To get 2HI I used to pull it all the way back into 4HI and then give the shifter a little bump forwards to get 2HI. It took me a while to get the feel for just how hard to bump the shifter forward. It sounds like you're in 4HI to me.
    Rene
  5. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    im doing what youve explained Rene. Its a pita getting worked. But i take the shifter boot off and watch. I get it till the 1 rod gets pushed in as far as it will go before the 2nd goes in also.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Weird...have you tried reversing after shifting out of 4 wheel?
    Rene
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Yes i have, Still spins, but obviously in the opposite direction.
