np205
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by chaney999, Dec 8, 2001.
  1. chaney999
    chaney999 Registered Member
    Jul 16, 2001
    11
    elgin.illinois
    72 k5 ? should the shift rail post (that has a tab welded to it) should the tab be 90 degrees to the shift rail link (plate steel that links the two shift rails) thanks...dean
  2. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    The rail with the tab is the range rail. I found a couple of different configurations of that “tab” when I was looking to replace mine… a simple rectangular piece of steel, and the one that’s on my case now which has a “nub” on it that meets the rail link. The tab is basically 90 degrees to the range rail, or parallel with the link. With my case in 4-low, (both rails in) it has about 1/16” clearance between the nub and the rail link. Hope this helps…
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    It not a range rail persay but the shift rail for the rear output. Has 3 detents high-N-low. Just as the front rail has the same 3. 2 high is simply the ft outputs in N
    72 Blazer 400TPI NV4500 NP203/205, 6 bolt FF14
    01 Suburban 8100 2500 4X4
