NP205's and OD Manual trans.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Jan 27, 2002.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    NP205\'s and OD Manual trans.
    First off, I'm getting psyched, we are starting to have our meetings for the upcoming truck pull season (stock class safety rules/equipment discussion tonight, since we had a few "mishaps" last year with clutches grenading).....sorry had to add.....but anyways, one of the guys in our club wants to have a manual overdrive tranny and the NP205 t-case. A.) I am an auto man and the only manual I have had any experience with is the sm465. B.) He is not the most mechanically inclined individual, but he does currently have a 83 K30 with swapped in sm465 and NP205 (was an auto with 400).
    He was looking for what Heavy Duty overdrive manual trannies are available to mate to a 205 and what will he need (adapters) to mate it to his current 205 (if it's possible). I don't know jack about this, so I told him I would ask for your input.
    TIA
    Chris
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  2. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    Re: NP205\'s and OD Manual trans.
    He could use a NV4500 adapted to a NP205, for something like that have him try Advance Adapters.
    <a target="_blank" href=http://www.advanceadapters.com/acrobat/gm.pdf>http://www.advanceadapters.com/acrobat/gm.pdf</a>
    A Clark or Eaton 5spd (Medium Duty Trannys)could be made to work with the 205 also, but I’m not aware of many “kits” for them.
    It would take allot of driving around in 5th gear to offset the cost of such swap if fuel economy is a concern.
    Joe
    79K10
  3. dyeager535
    26,979
    I can post the URL here tomorrow for an NV4500/205 conversion that was done (I believe) by a fellow CK5'er, including part number breakdown and pictures. If you want
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;www.dorianyeager.com/index2.html&lt;/a&gt;
    Why insist on counting when the ring gear has the tooth counts stamped in?<P ID="edit"><FONT class="small">Edited by dyeager535 on 01/27/02 06:52 PM.</FONT></P>
  4. Leadfoot
    Nov 28, 2000
    3,112
    Thanks guys!
  5. dyeager535
    26,979
    This help? www.dorianyeager.com/index2.html
  6. Leadfoot
    Nov 28, 2000
    3,112
    Sweet! Thanks, I'll pass it on. I don't know what will be different (as his was a sm465 and the tranny listed in the article is a 700r4), but it should give him a good Idea.
