np205tc gearoil or tranny fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoShow84, Oct 26, 2002.
  1. NoShow84
    NoShow84 Registered Member
    Aug 23, 2001
    35
    KANSAS
    i just put a 205tc in my 84 k5 with a slip yoke. as i am changing out the fliud i noticed it was tranny fluid and i always thought that the 205 took gear oil is this true or did some take tranny fliud /forums/images/graemlins/confused.gif
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    This has been discussed quite a bit. I run gear oil in mine but they say newer ones used ATF. Try doing a serch and you will probably come up with more info.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    80s they spec auto tranny fluid for increased mileage
    also extreme cold climates have a light oil spec
  4. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    208's run ATF. I thought all 205's run 80w90?
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Mine gets 80W90 gear oil, that's what the book I have for my '80 truck calls for.
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Well my books are old (76 FSM, 78 Clymers,& early 80s Haynes)so maybe there is some truth to the changing spec thing, but mine all call for gear oil.
  7. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I use 80W-90 GL5 in my 205. As others have said, this is what the older manuals call for.
    Will
  8. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I'm pretty sure my '88 crew cab had ATF in it when I bought it from the AFB. Ran ATF in it for some time until I installed Amsoil synthetic 80w-90, that's while I was pulling a 35' trailer. If the fluid is crappy looking run ATF in it for a few miles to flush it and then refill with your choice.
