np205tc ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoShow84, Oct 26, 2002.
  1. NoShow84
    NoShow84 Registered Member
    Aug 23, 2001
    35
    KANSAS
    i just put a 205tc in my 84 k5 with a slip yoke. as i am changing out the fliud i noticed it was tranny fluid and i always thought that the 205 took gear oil is this true or did some take tranny fliud /forums/images/graemlins/confused.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    205's that are connected to manual transmissions use gear oil. 205's that are connected to autos use ATF.
    Why? Because if the seal between those two leaks (and they commonly do) then you are not mixing two dissimilar fluids.
    There ya go.
    -- Mike
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    When I changed the tranny/t-case oil in my crewcab (SM465/NP205) the first time, ATF came out - I nearly had a heart attack! /forums/images/graemlins/eek.gif
    The shop I worked at had AllData, and ATF IS the correct fluid for the 465 and 205. Called GM to verify - same thing - ATF. /forums/images/graemlins/confused.gif
    Since I know better (/forums/images/graemlins/grin.gif) 80W-90 went in instead. Its quieter, and nicer to shift now. Go figure. /forums/images/graemlins/rolleyes.gif
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    According to Chilton section 1-28...
    A 205 TC would require SAE 80W or SAW 80W-90 GL-5 Lubricant
    A 203 TC would require SAE 10W-30 or SAE 10W40 engine oil
    A 208 TC would require Dextron II
    According to Chilton, you are supose to refer to your owners manual for K30/35 models
    I have always put 80W-90 in my 205's since it is gear driven just as a SM465. The 203 and 208 TC both are chain driven, so the requirements are different.
    just my $.02
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Hmm, that's very odd.
    I use gear oil in my 465 / 205.
    Interesting, but odd.
    -- Mike
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you trust a Chilton's manual?
    in the 80s chev specd auto tranny fluid to reduce parasitic losses
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I trust chilton only when it seems logical.
    I always have my opinion and usually want a second opinion so when we agree I trust them /forums/images/graemlins/smile.gif
  8. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    in 80's the 205 TC didnt exsist. with the exception of the K30's
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Incorrect at least for 1980 (imfamous year of slip yoked 205's on everything...K5, K10, K20, and K30). Years after it was mostly K30's that had them, but some K20's as well.
  10. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    jeeze, you are way wrong /forums/images/graemlins/grin.gif /forums/images/graemlins/eek.gif
