NP208 Adapter - Will it fit both 32-spline SM465 and TH350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rich, Sep 5, 2000.
  1. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    I just bought an '84 K5 for parts. It has an SM465 and NP208. I read that this SM465 in the later model K5 has a 32-spline output shaft as opposed to the 10-spline output shaft on older SM465's. I have 2 questions:
    1) will this T-case and adapter bolt to a TH350, or do I need to get a different trans-to-Tcase adapter?
    2) what is a good source for an old-style output shaft for this SM465 so I can run it with an NP205?
    Thanks!
    Richard
    '76 K-5 Blazer
    '90 K-5 Blazer
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    I don't think they are the same.Try http://advanceadapters.com.They should have a kit that has everything you need.
    Chuck Dirks
    81 Blazer
    Colorado,USA
  3. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    Cool, thanks!
    I just checked the Advance Adapters website, and it says the TH350 has 27-spline output shaft, so the NP208 T-case is definitely not interchangeable between 32-spline SM465 and a TH350 since the spline counts are different.
    Next 3 questions:
    1)A TH400 does have a 32-spline output shaft. If I want to get a NP205 to fit this 32-spline SM465, will a NP205 that originally came with a TH400 bolt up?
    2)Will the NP208 I have bolt to a TH400, or only an SM465 (so I know what to tell people when I sell it)?
    3)Has anyone ever seen a NP205 coupled with a 32-spline SM465?
    Thanks!
    Richard
    '76 K-5 Blazer
    '90 K-5 Blazer
