NP208 broken?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confedneck, Apr 29, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    hey guys... i got a real bad feeling i busted my np208 in my 86 k10...driving home from work today, in a real hurry, i heard what sounded like a chain grinding noise, it only does it above 1500 or so rpms, and when i hit the clutch at speed it goes away, any way to check that t-case without pulling it down?
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    are you sure its your t-case..???
    I'm going to try to make this short- but I had what sounds like the same problem...
    mine was the pinion nut- came off in my hands 2 turns.....check it.......
    do a search- with the title of my truck has a jake brake or something like that...thats where I solved mine.
    Brandy
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    If you broke it chances are good you wouldnt be moving at all. When I would kill Quadra-Trac cases, (Jeep full time chain drive I went thru 4 or 5, the next owner killed 2) it would make a popping sound when I would take off hard, that was the chain popping over the cogs. The last case that went in it TMK exploded the case completely when it finally let go.
    You mention pushing the clutch makes it go away, Throwout bearing maybe?
    My experience w/ chain drive cases is once your going along you can give it hell and its OK, its the chain flopping loose on take off that it shows itself.
