NP208 disassembly
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 81sb, Sep 26, 2002.
  1. 81sb
    81sb Registered Member
    Sep 26, 2002
    14
    Saskatchewan Canada
    Anyone familiar with pulling apart the 208. Mine is leaking where the front and rear cases bolt together. Can I pop off the rear drive shaft and just unbolt the rear section to reseal or do the internals come with it?
  2. GadgetK5
    GadgetK5 Registered Member
    Nov 5, 2001
    40
    Temecula, CA
    It's a little tough, and you could mess up your seals or bearings if your not carefull, but yes -- you should be able to just pull it off -- streight back. It may be easier (and less risky) to pull the rear retainer first -- this simplifies pulling the cover.
    The cover has two slots, one on each side (next to the bolts that have washers) that you can use to seperate the two halfs using a screwdriver.
    Good luck!
  3. 85chevy4x4
    85chevy4x4 Registered Member
    Apr 26, 2002
    63
    kansas city, kansas
    It's very easy to take apart. Drain the case. Drop the rear driveshaft and put a pan just under the rear of the case. Get an impact and a 9/16" socket and take off all the outside bolts. Then tap on each side of the case on the tabs. Have you pan directly underneath it to catch the remaining oil. Then pull it straight off. There is a needle bearing washer and two washers that will fall off of the shaft on the left side so be careful. It will slide off easily. Then when reassembling just clean each side very good and use black rtv and mate them back together.
  4. GadgetK5
    Nov 5, 2001
    40
    Temecula, CA
    There's also the mode fork return spring and cap -- putting those back on with the transfer case horizontal would be a challenge, I'd think. If you pull the rear retainer, I think you can guide the spring into place with your fingers; but if you don't, how would you get the spring to stay put? (I've only done it from the bench).
    You're right, though, the rest is pretty easy.
