np208 drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84K5cedric, Aug 19, 2002.
  1. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    After installing my 4" suspension lift, I noticed my front shaft seems pretty short. And whenever I'm at speed and let off the gas partially, I get what I can only assume is U-joint vibe. I also hear and feel it when wheeling up a steep incline. I've read here that the stock spacers under the tcase and be moved to facilitate the drop. What I want to know is how does this work with the back of the tranny? will it follow with no additional work necessary? Is this, in effect changing the drive line angle (starting at the engine back to the tcase)? If so, wouldn't dropping the tcase actually increase the angle of the front u-joints?
  2. Yuba K5
    Yuba K5 Registered Member
    Jul 31, 2002
    31
    marysville ca
    when you drop your t case at the cross member it puts less angle on your rear driveshaft but more on your front.i went through this when i put a 6in on my 90 blazer(700r208)what a nightmare.you should be alright with a 4 in lift. maybe a litle grinding on the front shaft.
  3. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    in my 4" kit the spring pack had an angled shim installed so the rear shaft is fine. So it sounds as if dropping the tcase to fix the front shaft (which is showing alot more yoke(?) at the back of the diff) would actually hurt my cause. What about angled shims such as those which were on the rear spring pack? any reasons why I couldn't make or find something like this to take care of some of angle?
  4. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    What did you mean by a little grinding on the front shaft?
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    there are little "ears" in the cv on the front shaft that limits travel in the cv..you can grind them out without any ill effects..it gives you a few extra deg of travel from it /forums/images/icons/grin.gif
  6. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    I'll look into grinding out the "ears". But while I'm at it, is there any thing wrong with putting an angled shim under the front spring pack to eat up a few degrees?
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    you would be doin alot of shimmin...i would just grind the ears and see what happens...its a free and easy fix if it works..
