NP208 for TH350
Discussion in 'OffRoad Design' started by rich, Oct 8, 2001.
  1. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    My friend has an ailing NP203 in his Jimmy and would like to replace it with an NP205. However, NP205's for TH350's are hard to find around here, and the driveshafts to fit them in a Blazer are even harder to find.
    Is an NP208 another option? I know that the NP205 is the strongest, but an NP208 is plenty strong for this application. I like the lower gearset of the 208, and 208's are more plentiful than 205's. But most 208's seem to be behind TH700's, not TH350's.
    Were there NP208's offered for TH350's? What's the difference between a 208 that's bolted to a TH350, and one that's bolted to a Th700? Is the input gear different? Is the adapter different?
    Thanks!
    Richard
    Raleigh, NC
    '90 K-5 Blazer - stock, daily driver
    '76 K-5 Blazer - 14-bolt FF, 4.10's, locked front and rear, 36's, SM465/NP205
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i have a th 350 and a 208 and it is decent , just make sure u have a beefy skidplate . ..... i have busted 2 of the alum housings , so i have a new one the truck and one frankencase cuz its all welded up and stuff for a spare . ive never seen a 700trans 208 in my travels .....but i think they are the same ....
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I know the factory used TH350's with NP208's, but I don't know the combination of adapter, input gear and output shaft required to make it work. Maybe post on the big board and see if anyone else knows?
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  4. th350s that came with 208s have a longer output shaft
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  5. crewcab
    crewcab 1/2 ton status
    Oct 14, 2000
    396
    i have a 350 208 for $500
  6. crewcab
    Oct 14, 2000
    396
    also have np-205 for turbo 350 w/ drive shafts
