NP208/Front Driveshaft Bolts
Discussion in 'The Garage' started by tsquared275, May 22, 2006.
  1. tsquared275
    tsquared275 Registered Member
    Jun 28, 2005
    13
    Plano, Texas
    I know this maybe a waste of someone's time, but I was wondering what size bolt is used to attach the front driveshaft (for an 84 Blazer) to the transfer case (NP208). Any help is appriciated.
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Hmm, havent pulled mine for awhile ( sounds kinda personal ) but I'll guess 3/8 th's.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    M12 Iirc
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The bolts that hold the shaft on on my '83 K20 with a 208 take a 5/8" wrench. I think the bolt size is 7/16". I know they aren't metric because I just built a new front shaft for my truck and tried to use a set of new 12pt, 12mm bolts. They wouldn't screw into the flange.
    The M12 bolts are the ones used on the flanges like HAD sells. 12 point, 12mm metric wrench to remove them.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    there 7/16 14 thread 1" long use lock washers- Jess
