Np208 gasket!!!! ugh
Discussion in 'The Garage' started by eclipse, Jan 22, 2005.
  1. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Ok so I had to replace my np208 in my 85 K10 which is a 4spd. So after I picked it up a I stopped at my local auto parts store and asked about a gasket for the t-case. They told me there wasn't one so I went home and installed it. Then someone told me there is suppose to be one between the 208 and the adapter. I let for Maui for a week with my K10 in my shop and when I returned I had a quart of fuild on the floor from the transefer case and it looks like it leaked out of the front where it bolts to the adapter. None of the auto part stores I have contacted in town can find if there is a gasket. So is there suppose to be a gasket between the 208 and the adapter? Or could my input shaft seal be leaking up there? :confused:
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Yes there is a gasket...mine came in the bearing/seal kit...I F'd it up lifting that heavy sob back into place, so I cleaned the surfaces and used RTV...let it skin over about 45 minutes while I did other things...gave it another go, and buttoned it all up....No leaks for about 3 weeks now... www.nationaldrivetrain.com if you feel you really need one
    Also, when I took mine apart, there was only a couple Tablespoons of fluid that dripped out from there...and that was Before I replaced all the seals/bearings...
  3. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    thanks :thumb:
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I get mine at my local tranny shop. He has tons. Sometimes he charges me!!
  5. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Last time I dropped the t-case, I damaged mine. I ended up making one out of gasket material because the dealer was the only one that carried it and they wanted $10 for it and the gasket material was $3 for around 3ft. of it. Just an idea.
    Ray
