NP208 help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by goblazeinco, Nov 1, 2002.
  1. goblazeinco
    goblazeinco Registered Member
    Nov 9, 2001
    33
    Longmont,CO
    I have an '86 with a NP208 t-case, automatic,dana44 and 14bolt ff and .Here is the problem I get a rumble when I am on the gas lightly, when i give it more or let it off completely it stops. It does it in both 4wheel dror 2. I think it could be a bearing in the t-case. Does anyone have a comment on this or any better ideas. Also, how hard is it to rebuild a np208 t-case? /forums/images/graemlins/k5.gif
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    It sounds like a vibe caused by incorrect pinion angle.
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I have the same sound. Sounds like a pipe being dragged on pavement right. Its pretty loud when coasting at freeway speeds. Frizz is right, its due to your pinion angle. If you're still running your stock driveshaft, look into getting a CV shaft made. I tried using degree shims on my extended non-CV shaft and the vibes are still there.
