NP208 leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Sep 2, 2001.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My 208 is leaking from the rear output. How hard is it to replace the seal, should I try and rebuild it at the same time? How hard is it to rebuild a 208? My truck has 145k on it, and a fair amount of time in 4 wheel drive and has never been rebuilt. thank you
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The seal is real easy to replace. Remove the drive shaft, take a srewdriver and pry the seal out. Then tap the new seal in with a hammer. Sometimes the seals are in there really good, so you have to take a hammer and tap the screw diver between the seal the the transfer case.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I've replaced my 208 seal twice, first time it didn't go in strait and leaked, second seal it worked fine.
    It's easy be sure to park up hill so "t" fluid wont leak out, pull shaft out. Then pull gasket, and tap in new one with a rubber mallet. Should take only 10 minutes.
    KEN
    Ps. You shouldn't have to worry about rebuilding the case, just keep up the maintenance.
    DANGIT it's not a bronco!
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Shouldn't I park down hill to keep the fluid from leaking? Its the rear output that is leaking. Just wondering?
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Park with the front pointing downhill. I think he meant that you need to have the back up higher than the front.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Oh ya how often should I change the t-case fluid? thanks
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is the seal a dealer part or an Autozone Part? thanks
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Just about any parts store will have one.
  9. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I paid $4 and change for mine from Napa - put a light coat of RTV or Permatex #2 around the new one before you seat it, and it will stop any possible leaks, and also make it easier to change the next time.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  10. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Ya I ment park with the front down ward. And that is a good tip using RTV.
    Take your time putting in the new seal. GOOD LUCK.
    KEN
