Np208 low range
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Mudologist, Aug 15, 2001.
  1. Mudologist
    Mudologist Registered Member
    May 9, 2001
    57
    Hazleton, Pa 18201
    Deos anyone know of a company that makes and sells low range kits for NP2-8 transfer cases?
    2.61:1 in not cutting it anymore.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    AFAIK no one makes replacement gear kits for a NP208.
    You should look into a "Doubler" from Off Road Design
    <a target="_blank" href=http://www.offroaddesign.com/catalog/doubler.htm>http://www.offroaddesign.com/catalog/doubler.htm</a>
    You get to keep a "normal" low-range and also have a "4:1" low-range. ORD has a forum on this sight...check it out.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. Mudologist
    May 9, 2001
    57
    Hazleton, Pa 18201
    That's pushing the rear drive shaft length in a K5 with 8 inch suspension. Does an atlas ll come with the front shaft on the passanger side?
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,385
    E-town baby!
    The Atlas can be either passenger or driver side drop...it can also be 'clocked' for clearance or better drivetrain angles.
    Rene
