NP208 (M) or (A)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bassphreek, Feb 17, 2001.
  1. bassphreek
    bassphreek Registered Member
    Feb 17, 2001
    25
    nj
    is there a difference between the np208 that i took off my '85 sm465/np208...and the np208 i took off my '85 700r4/np208? is there a spline difference, if so....will the one i took off the 700r4 bolt up to a th350?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes there is a difference.
    465/208 has 32 splines
    700r4/208 has 27 splines
    The 208 WILL work with the th350 providing you get the necessary spacer to fit between the adaptor and tranny.
  3. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    The output shaft on the TH350 is about 2 inches shorter than the 700R4. I think advance adapters make a output shaft for the conversion. Check it out at <A target="_blank" HREF=http://www.advanceadpters.com>http://www.advanceadpters.com</A>
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
