NP208 needed
Discussion in 'Rocky Mountain Region' started by BLZN4FN, Mar 19, 2007.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Anyone have a NP208 that bolts to a 700R4 trans? Or knows how to rebuild/build one I have 2 208's that are in peices in a box and one in the K5 now.
    I need this done asap for Moab looking on the cheap side;)
  2. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    I have one that I was going to pull apart soon, to swap the dodge fixed yoke parts to. But if you need you can use it.:D
    Z
  3. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I know where you could get a cheap, maybe free NP241 that was behind a 700r4. Catch is that it leaks. Not horrible, but definitely noticeable.
    You know the 241 is a stronger case and chain than the 208. Plus lower low range. It's just sitting on the ground here at the shop...
  4. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    what is the difference between the two? where is it leaking at rear housing output seal or case?
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    It's leaking where the case seals together....and I may have chipped a chunk of the case off at Blazer Bash '05 :whistle:...nothing structural :crazy: :haha:.
    Trade you it for some zero-rates :deal: :D
  6. rhino105amx
    rhino105amx 1/2 ton status
    Sep 13, 2002
    159
    Mesa, Arizona
    It will bolt right in where a 208 is. The only difference is that only a 241 out of an 89 has a mechanical speedo. The others are electronic. Some say you have to modify the shifter, but my 208 shifter bolted right up to the 241 without any modification at all.
  7. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Yes it is Nick's old tcase. And you will need to use your shifter.
    I don't know what you've got for a speedo setup, but this one is the electronic version.
  8. B_to_C
    Jan 15, 2003
    1,861
    Think Bo needs a speedo (wow, NOT a good visual :eek1::haha:) when he's crawling along the trails at 5mph, then back onto the trailer?
  9. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    YES! :tongue1:
    If he has a speedo I'll come on the next wheelin' trip and get plenty of pics. :doah:
    You know we observed the case only leaked when you'd driven all the way here from Boulder and got nice and warmed up. Bein' the Puncher is a trailer queen, it may not leak that much at all. On the occasions your truck sat here it didn't leak.
  10. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Is it leaking from the seal only or from where the case has a chunk missing? Is there any way you or Scott could snap a pic for me?
    I have your Zero rates in a box. Deana was going to take them to the post office but I found them in the back of her Kia:screwy:
  11. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I can get you pics of a dirty transfer case. I never noticed the chunk he's talking about. I think it was leaking before that from what I remember. It is my stained shop floor after all. :haha:
    It's not leaking from the seals; IIRC it's coming mostly from the case split or seam.
  12. B_to_C
    Jan 15, 2003
    1,861
    Yea....the case has two halves that bolt together...that center "seam" is where it leaks. The missing chunk is purely cosmetic. FYI i tried using JB Weld on that center seam, so if you're going to try and get that back to OE specs you're going to have to deal with that.
  13. GMCJason
    GMCJason 1/2 ton status
    Dec 23, 2004
    242
    Longmont, CO
    My 241 leaked from the center seam, too. I pulled it apart when I put the SYE on it and then put it back together with some RTV - no more leaks. It's pretty simple to fix.
  14. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Yeah but we're talking about Nick here!
  15. GMCJason
    Dec 23, 2004
    242
    Longmont, CO
    True, but you can have Liam supervise - he'll be fine. :D
  16. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Yeah but then Nick gets distracted with Liam's toys. :haha:
  17. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If the 241 doesn't pan out and you are still in need of a 208 badly let me know. I have 2 extras for my truck (1 27spl, 1 32 spl). I don't want to get rid of them but I could part with one if a friend is in need. Let me know.
    Rebuilding a 208 out of the 2 parts cases you have wouldn't be very hard. 208's are pretty simple tcases.
    Harley
  18. BIGNICK91
    BIGNICK91 1/2 ton status
    Jul 10, 2006
    384
    ARVADA, CO
    Hey don't bash the JB weld i tried that on my 241
