Np208, Np208c, Np241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Dec 17, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Are there any differences between the 208 and 208c? I also heard to avoid 241s from 93 and after because they are weaker. Is this true? Whats the difference that makes them weaker? Thanks.
    Brian
    84k5
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    an NP 208C is for a Chevy, but its a regular NP 208. The NP 241 is a little stronger than a 208 and it has a 2.72:1 low range insted of the 2.61:1 for the 208. The 241 also has a better lubing system.
    90K5
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Thanks for the response, but I already know the diffreences between the np241 and np208. So the c just means it is for a chevy? And are later np241s different than earlier versians?
    Brian
    84k5
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I think that the letter designation is typically used to identify what vehicle the transfer case is used in. For example, the 231 used in Dodge Rams is a 231D and the one in Jeeps is a 231J. There can be some internal and external differences between different versions as they are kind of "fine-tuned" for each specific application.
  5. Danivek
    Danivek Registered Member
    Dec 18, 2000
    24
    El Paso Texas
    Do you thinh it would be a good idea to change from a 208 to a 241?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You wouldn't gain much by going from a 208 to a 241, just .11 of low range and a better lubing system. I'd just keep it full and it'll be fine, the 208 is still a good t-case.
    90K5
  7. The only big advantage to the 241 over the 208 is you can buy the slip yoke elim kit and a 4:1 low for the 241.This is the reason I'm thinking about going to a 241.
  8. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    If you needed to change transfer cases anyway, and the prices were pretty close.....than yes, I would get the 241.
