NP208 Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Jimmyish, Aug 14, 2001.
  1. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    Every once in a while when driving in 4Hi, my transfer case seems to slip out of gear and start grinding, (real nasty noise) I have to turn the truck off to put it back into gear (putting in P or N doesn't do it) - any ideas?
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Go take a look under and check the t-case's 4 bolts that mount to the tranny. I was so freeken stupid, after putting on a 2.5 inch lift, and after 18 years of service the four bolts had loosened up. Enough that they were only finger tight "FINGER TIGHT" It caused the t-case to pop while in 4hi and low. and even when in 2. I put on a crap load of Lock Tight. and no problems since.
    Good luck.
    DANGIT it's not a bronco!<P ID="edit"><FONT class="small">Edited by DuneRunner on 08/14/01 12:30 PM.</FONT></P>
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Mine pops out of low a lot, I don't use 4 high, when it happens I put the trans in nuetral and give firm yank on the t-case shifter. Just do it quick.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
