NP208 Speedo Drive Gear?
Discussion in 'The Garage' started by DukeBoy88, Apr 5, 2005.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I did a search and found Pauly383K10's list of speedo gears. problem is I have a brown drive gear (4" long cylinder) that came stock with my M1008. I didn't see that on the list. I have regeared the truck with 3.73, and have kept the 235/85 R16 tires. My speedo reads 55mph when traveling approx 65mph. I didn't count the teeth when I had it apart, just noted the color because I remembered there was a list. anyone know how many teeth? Thanks in advance.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    im guessing you have a auto trans??
    I cannot even find ANYTHING for my SMC465/NP205 to fix my speedo...
    same problem but im good up till 45mph.. accurate then but at 50 im doing 60 and at 55mph im doing like 68!!!!!
    good luck...
    can ya post anything you find in your endeavors on my setup?
    just ironic that there are so many people with my setup but no one fixed their speedo's
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
  4. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    I just tore my tranfer case out again to seal a leak I missed and my driven gear is 15T but I swear its tan in color not gray. anyway a blue 18T should correct my speedo, and I happen to have one already so it'll go right back together. thanks again.
