np208 t-case
Discussion in 'The Garage' started by Justin Fleming, Sep 8, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    765
    4
    Oxford MI
    Wondering about the speedo adapter. I thought that it was leaking tfluid from that area....when I crawled under the truck I noticed that the spedo cable was finger tight. Is this where the fluid could have been coming from? also while I was under that I decided that I should take a look at the o-ring on the spedo adapter and when I pulled the bolt out t-fluid came pooring out everywhere. Is there suupposed to be tfluid that high up?
    thanks
    Justin
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If the speedo adapter lies below the fill plug , then yes fluid will come out .
    Being finger loose would cause it to leak a little .
    Tighten it up , clean it off , top it off with ATF , and go for a drive to be sure .
  3. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    I think the speedo is higher than the fill plug.... I will investigate tomorrow
  4. Bunker Buster
    Bunker Buster Registered Member
    Jan 25, 2005
    36
    Lowry Crossing, Tx
    The speedo housing is in between the fill plug and drain plug, so you are going to lose fluid if you open it up.
