NP208 Tailhousing Removal Question
Discussion in 'The Garage' started by BustedTrojan, Sep 25, 2005.
  1. BustedTrojan
    BustedTrojan Registered Member
    Aug 2, 2001
    I'm taking off the rear tailhousing to replace the bushing which will hopefully fix the leak. I removed the four bolts, I could see, and the thing doesn't budge. I banged on it with a hammer and that didn't do any thing. I tried getting a screwdriver to pry the seal loose and that didn't work. Are there more bolts, or do I need to go to the gym? Anybody got any tricks to try?
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    Lynchburg, VA, USA
    If its a mid 80s to 90 mechanical speedo, the tailshaft piece is indeed only held in by those 4 bolts. There is no gasket, just GMS or silicone holding it together, so its probably pretty tight. Since the aluminum is very thin, I would not recommend hitting it with a hammer. If you must, then use a rubber mallet. You can probably pry it apart, just make sure you take care and dont gouge the mating surface. Good luck...
