NP208 Tailhousing removal
Discussion in 'The Garage' started by Hossbaby50, Aug 21, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I picked up a used 208 to replace mine. The new case has a piece cracked out of the rear tailhousing where the rear seal goes. I want to swap my old tailhousing onto this new case. I removed the bolts for on the new case, but can't get the rear housing off.
    I can't get anything into the joint to pry it off (also affraid I will crack the aluminum). I am also affaid to heat the housing because of the plastic parts inside the tailhousing. How should I go about getting of the old tailhousing? Thanks for any input.
    Harley
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    If I remember right, remove the speedo gear. It's on the passenger side of the housing.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I did remove the speedo gear. My problem is I can't get anything in the crack to pop the case open. it is sealed with RTV and the gap is to small to get anything into. Sorry, I should have mentioned that.
    Harley
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I'm trying to remember. Don't think anything came off the shaft....Hmmm, did ya get all the bolts off?
    It's been awhile since I took mine off and don't remember having any trouble.
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I gently tap on the fins with a hammer to get the tail housing to spin a bit. Then it comes right off. I have not broke one yet.
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    id reccomend a rubber or rawhyde hammer, steel banging on aluminum might have some consiquenses. /forums/images/graemlins/thinking.gif
