np208 to a np241
Discussion in 'The Garage' started by noho blazen, Jan 7, 2007.
  1. noho blazen
    noho blazen Registered Member
    Oct 7, 2006
    19
    mass
    i have a mechanicle speedo np241 and want to swap it into my truck with a np208 and i was woundering what was in volved in this swap
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Unbolt the 208 & bolt in the 241. It should be a direct swap with mech speedo's as long as they have the same input splinecount.
    Harley
  3. noho blazen
    Oct 7, 2006
    19
    mass
    thanks they both came off a 700r4 the splines should be the same
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Then it should be a direct swap. Just remember it will take about 4-5 quarts of ATF to fill the case up.
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Also, the little arm that bolts to the case that connects to the shifter needs to be swapped too. The angle is about 90* off. Just need to pull the cotter pin IIRC.
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Yep, literally a bolt in swap, less changing the shifter arm out :)
  7. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Very good point, Just got done swapping out a 32spline 208 for a 241 in my yard truck and left the arm/linkage attached to the shifter.Big surprise when I tried hooking it up to the 241, first glance they look the same!
