NP208 to NP 241 Swap... What do I need? (Have the 241)
Discussion in 'The Garage' started by foxman, May 11, 2004.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Just picked up a NP241, and want to replace my leaky 208... What is intailed? Anybody done one before?
    Are they a match as far as the shafts/allignment goes? I know something would have to be done to switch the electronic sensor for speed... right?
    Also Is there a slip yolk eliminator I should be looking at while I'm doing the job? I know some people swear by these things and I figure may as well cause I got the T-case for free...
    Any helpful hints would be appreciated... /forums/images/graemlins/cool.gif
    Jeremy
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its a direct bolt in, as long as both tcases came from the same tranny. not sure on the speedo part.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    ORD carries the SYE kit
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    As long as the 241 came from behind a 700R4 then it will bolt up. If you do a SLE kit you will need to do driveshaft mods for the rear.
    Harley
  5. foxman
    Oct 22, 2001
    251
    Detroit MI
    What about the speed sensor and electronic plug? How do I Get them to match up? I know there's a difference in the two tailshafts, just not sure what it is yet.
    I was also going to replace the drive/driven gears in the NP 241 in order to correct the speedo reading.
    anybody know if they the 208 to 241 swap requires anything other than time/fluid?
    Thanks..
    Jeremy
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If you have a 241 and it is from a 700r4 and your 208 is behind a 700r4 it is a direct bolt in swap as long as your 241 is from an 89 and has a speedo gear. If your 241 is a 90 or newer you will need to replace the speedo housing and install a gear in place of the sensor ring. The output shafts are the same so it's all bolt on. If you need the speedo parts pm me. I have them on a 241 that came from my 89 Jimmywhich I'm keeping for a spare case for the 90 but don't need the speedo parts.
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Totally off topic but Wayne do you still have a frame from your old Jimmy or blazer. I will be needing one and thought I'd ask. I have a friend looking but I remembered you having one last year.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No, when I was finishing up with it I found some serious rust in the frame at the front cab mounts so it was scrapped.
  9. 300stw
    300stw Registered Member
    Jul 4, 2002
    51
    Culbertson Montana
    wayne interested in your speedo parts. am putting a 700r4 and a 241 in a 72 chevy if i can get the speedometer set up for the 241. email me 8mag@outdrs.net thanks
