NP208 to NP241 linkage question
Discussion in 'The Garage' started by wforicv, Oct 15, 2005.
  1. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    Swapped in a NP241 for a broken 208. The linkage SHOULD be the same, right? I thought my old linkage would work from my 208. Can't seem to get it to work with the 241. Anybody got a pic of a 241 linkage? It seems like the arm is not "angled" right.
    Eric
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Same shifter and linkage.
  3. wforicv
    Feb 16, 2004
    165
    Thanks man, it must be all about the angle of the dangle.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    nope not the same.
    The 241s shifter arm is different. Its clocked 90* differently then the 208. Best bet is to jut cut it near the end where it bolts to the case, turn it 90* and weld it back together. Or if you have the 241 shifter arm, just replace the 208 one with the 241 piece.
  5. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    good to know I thought it was a direct swap
  6. wforicv
    Feb 16, 2004
    165
    Thanks sled dog, I thought I was going crazy :doah: . I do not have the 241 shifter arm. Does anyone out there have a pic of a 241 arm? Better yet would be a pic of a modified 208 arm.
    Eric
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I can try to get you a pic of a np241 arm tonight or this weekend. I have 2 np241 shifters also. :D
  8. wforicv
    Feb 16, 2004
    165
    Thanks, that would be great.
    Eric
  9. rhino105amx
    rhino105amx 1/2 ton status
    Sep 13, 2002
    159
    Mesa, Arizona
    I just did the same thing and the 208 shifter bolted right up to the 241. I got the 241 shifter with the T/C and it is the same as my 208.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    the metal plate that bolts to the transfer case itself? I swapped a 241 for a 208 and the shifters were different. Ryan(Tork) swapped a 208 for a 241 and also found the shifters to be different, he is the one who thought of just cutting, clocking, and rewelding the 208 shifter.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i helped a buddy swap a 241 from a 89 blazer to his 87 k10 and the linkage was the same, didn't need any adjustment either.
  12. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I am doing the swap right now. I am replacing the NP208 on my 86 K5 with a 241 from a 89 K-5 and the linkages are exactly the same.... :dunno:
