NP208 transfer case help
Discussion in 'The Garage' started by williamsondm, Oct 3, 2005.
  1. williamsondm
    williamsondm Newbie
    Oct 3, 2005
    Oceanside, CA
    I've got my tranfer case stuck in 4WD low. No matter what I've tried, I can't get it out of low. Is my transfer case shot? I have a full size 85 Chevy Blazer, 350 with 700R4 transmission. The transfer case was supposedly rebuilt when the transmission went out last year. I've adjusted on the linkage. The transmission will shift gears, but no matter what position the shift lever is in, it is always in low gear.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Sounds like a mess.
    Are you saying the shifter on the t-case moves through the selections, but is still in low no matter what range you select? :confused:
  3. williamsondm
    williamsondm Newbie
    Oct 3, 2005
    Oceanside, CA
    Np208
    Yes. The lever moves forward or back. The transfer case will actually disengage if the lever is not all the way back into the 4WD position. No matter where the lever is, if it actually stays in gear, it is only in low gear. It will stay in 4WD low if the lever is pulled back. The transmission itself does shift through gears. From everyone I talked to, the transfer case is bad. This is the second rebuild on it in about 3 years. I've been deployed to Iraq twice during the time so the truck did not get many miles on either of the rebuild jobs. I think I'm going to replace it verses having it rebuilt. I'll go after the shop with a civil suite after I determine what went on with this one.
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    so, if you have it in 4hi and you hit a bump it will pop back into 2wd? mine did that too, but it was it wasnt fully engaged. i had to grind the shifter rail where 4hi is about a 1/4" so 4hi will be fully engaged. and my 4lo would always stay in gear. so, if that sounds like what yours is doing then try grinding the rail thing back alittle to make sure it fully engages.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I remember driving my truck home in low after that happened . In my case the pads were worn off the shift fork , and the fork itself was knife edged . I ended up with a 50 buck case from a local friend and put my input gear in with another friend since it was the wrong spline .
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    It sounds like the range fork has been completely chewed off. You are probably getting in and out of gear with the mode fork. I wonder if it is shifts into 2WD LO when the lever is all the way forward.
    If adjusting the linkage didn't help, it's time to tear into the case. It may need nothing more than some forks and pads to be fully operational again. I think that this kind of fork wear is due to improper linkage adjustment.
  7. redneckboy35
    redneckboy35 Newbie
    Mar 15, 2007
    greesboro
    ive got a full time 4wd transfer case and i need a 208 that fits a th350 tranny...if anyone has anything please get back!!!
  8. silveradoreb
    silveradoreb 1/2 ton status
    Mar 11, 2005
    150
    Boone,NC
    Mine does the same thing, I ordered a 205 off ebay yeasterday to fix the problem
  9. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I have a 27 spline 208 if you need one. It should bolt up to the 350. $75 plus shipping
