np208 v/s np241
Discussion in 'The Garage' started by bigarmzz, Oct 14, 2006.
  1. bigarmzz
    bigarmzz 1/2 ton status
    Feb 21, 2005
    184
    elkins, west virginia
    i've noticed (through lots of reading of old threads) that alot of guys are switching from the 208 and going with the 241 transfer case
    why exactly? the 241 is computer controlled, isnt it?:confused:
    i got a 86 k-10 with the 700r4/208 combo, and have been thinking about finding a 241
    any thoughts?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    241 has slightly higher low range. its internals are stronger, and there is an off the shelf sye kit for it.
    '89 241 was only year of mechanical speedo. '90- were electric
  3. bigarmzz
    Feb 21, 2005
    184
    so...if, and i mean "if":( i found a 89 np241 it would bolt right up, mechanical speedo and all to my 700r4, right?:confused: ...i'm thinking i read that both are 27 spline, right?
    then i could just buy a sye and be set
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep bolt right in. just make sure the 241 is from a 700r4 :)
  5. bigarmzz
    Feb 21, 2005
    184
    cool thanks:bow:
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Ok, here's a couple of questions; do the 32 spline and 27 spline inputs interchange? Are the guts the same between driver and passenger drop-- just different housings?
    Thanks, Jimbo
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you can use a '90- np241 and then just swap the speedo housing. would be perfect time to also do sye if u went that route
  8. bigarmzz
    Feb 21, 2005
    184
    so i can use a 90 np241, just change the tail shaft....hmmmm:thinking:
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yes sir. ive got one for sale in the classifieds :deal: those were my initial plans
  10. bggrnchvy
    bggrnchvy Registered Member
    Jan 21, 2005
    48
    Cupertino, CA
    The 32 and 27 splines do interchange, they use the same bearing and seal. Ive done this personally and have pictures of the measurements if you would like proof.
    P-drop and D-drop have different gear tooth profiles form what Ive heard as the newer ones where cut differently to be quieter. The interchanging results in damage from another source.
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If your 208 is in ok shape and you don't have need or are planning to go SYE in the near future spending money on a 241 just to replace a good 208 is a waste of money. The 241's lowrange and strength advantages are not significant enough to warrant the swap unless there is a motive behind it like a junked 208 or the need for a SYE ASAP.
    Harley
  12. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    If you do decide to go the 241 route, make sure you also get the plate that bolts to the shift rod on the transfer case side. The one from the 208 is shaped slightly different.
