NP208 won't stay in gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Steve#1, Feb 16, 2002.
  1. Steve#1
    Steve#1 Newbie
    Oct 9, 2000
    4
    Plano TX
    NP208 won\'t stay in gear
    Howdy guys,
    I've got an '87 K5 with an NP208, that won't stay in 4hi or 4low. It will stay in nutral. I'm gussing that something just needs to be adjusted since the problem started after a tranny rebuild.
    Any help would be appreciated.
    Steve #1
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Re: NP208 won\'t stay in gear
    Same problem here. I've been told it could be shift linkage adjustment, worn shifting forks, or worn transmission mounts. With my luck, its all of the above on mine. Any experience advice her is appreciated.
    Tom
    Don't follow me, I won't make it.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Mine would jump out of 4lo after I installed the body lift. Chiltons and haynes manuals tell how to adjust the linkage...they can be handy sometimes. Ill dig mine out this afternoon and see how I did it.
  4. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Insight anyone?
  5. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    You may want to pull it the shift forks have plastic shoes that wear out mine started jumping out and now I had to replace the shift fork chewed the shift feet off of it so lucckily I found one in the JY for 100$ then spent yesterday swapping parts(the one in the Jy was a stick)
