np208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by motofool, May 7, 2004.
  1. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    i know its aluminum but are these cases very tough?
    are they gear driven or chain driven?
    looking ata truck that has one and im coming off a crappy np203...
    gimmie some insight would this transfer case be okay light to medium offroading and pavement pounding.
    3/4ton LWB 350th400np208 lifted 4"
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    REPOST!!! /forums/images/graemlins/grin.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Chain driven aluminum cased. 2.61:1 low range (better then a 203 or 205 in the low range area). Slipyoke rear output.
    I run one in my truck and have since day 1. The original case lasted 18 years before I rebuilt it last fall. I am now running the same case with a few new bearings.
    I have no problem running this case. I like it alot and the low range allows me to crawl very well. I run a mild 350 with MPFI which makes pretty decent power. I rock crawl though so my case never really see's the high RPM outputs of a mud runner or things of that nature. I like the case and think it is a good case.
    You must make sure that you have a skidplate so you don't samck it on a rock otherwise you will crack the case. I had a custom crossmember/skidplate built by 4x4 Iron.
    Don't let everyone scare you about a slipyoke rear output. As long as you don't have insane rear flex you should be fine. I run 5" lift, 35" tires, and a 14bff. I still run stock rear driveshafts. The 14bff move the pinion forward about 1" over stocks so I didn't need to lengthen my driveshaft. For the lift I added a 4* taper to the rear axle and I get no vibrations.
    I am locked front and rear and so far so good. I don't have alot of time in on the rocks yet but next wheeling season will be the true test of the cases longevity. I am not really worried about it though. It should do just fine.
    Harley
  4. motofool
    Apr 7, 2004
    361
    DFW tx
    cool im probably gonna pickup this th40 and np205 for safe keeping then and just let it chill til something breaks.
