Np208
Discussion in 'The Garage' started by kkyle69, Aug 4, 2005.
  1. kkyle69
    kkyle69 Registered Member
    Mar 9, 2005
    13
    Huntsville, Texas
    :confused: What is the piece called that connects from a NP208 to the Front Drive Shaft. I need to find this piece. It kinda looks like a small drive shaft. Its needed to clear the Trans/Transfer Case Crossmember.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The yoke?? They make a spacer also that goes in between the yoke and the flange on the DS to spacer it out from the crossomember.
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    do you mean the double cardan joint that is at the transfercase end of the driveshaft (looks like 2 u joints in a cage)?
  5. kkyle69
    Mar 9, 2005
    13
    Huntsville, Texas
    Yea, Thats it. The two u-joints in a cage. Do you know where I can get one?
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    any driveline shop can get those.
