np208
Discussion in 'The Garage' started by chevy9534, Feb 26, 2006.
  1. chevy9534
    chevy9534 Registered Member
    Jan 4, 2006
    21
    texas
    I have an 88 k5 and the owners manual suggests atf fluid for the transfer case. I was reading some threads about 205 and 203 and they say its ok to use 80-90w oil because its thicker. Could i run this in my transfer case or not?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i run atf in my 208
  3. chevy9534
    Jan 4, 2006
    21
    texas
    atf is what i have in it now. Its slipping out of 4 HI and i didnt know if a thicker fluid would help or if its time for a rebuild
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the last 208 that did that to me was in bad need of a rebuild, but it could also be that the linkage is not adjusted correctly.
    i wouldn't run 80w-90 in a 208, its too thick.
  5. chevy9534
    Jan 4, 2006
    21
    texas
    how do you adjust the linkage on it.
  6. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    The 208 uses atf the 203 is 10-40 and 205 80-90
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on the linkage to the tcase, at the shifter end is 2 jam nuts and the part that hooks in the shifter. loosen both nuts, put the tcase in 4low, put the shifter in 4low, and adjust till it just slides in the shifter. then tighten the nuts.
