NP241 bolt in replacement for NP208?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomnits, Nov 27, 2000.
  1. tomnits
    tomnits Registered Member
    Nov 27, 2000
    17
    I have a 1985 with a 700r4/NP208. The NP208 is kaput, cracked housing. I have access to free NP241 from a 1990 solid axle Blazer (also 4sp auto - 4L60E? I'm not sure what the last year was for the 700r4). Does anyone know if the NP241 will bolt up to my 700r4? I was thinking of getting the slip yoke eliminator kit if I do the swap. Or should I stick with a NP208? Which t/c is better?
    TIA
    Tom
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    If I'm not mistaken the 700R4 and the 4L60 and the 4L60E are the same transmission, except the 4L60E is electronically controlled. I would think as long as you got the adaptor that goes with the 241 you should be alright. I don't know if there is much of a length difference between the 208 and the 241, you may need different driveshafts.
    Rene
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    487
    Grand Rapids area
    You'd better check on the spline count for the 700R4 output shaft and the NP241 input. Otherwise, you should be able to tell by looking at the two 'cases whether or not you can use the 241.
    "They tell me that you can make it to work without big tires. I'm still not convinced."
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I don't know about the difference in spline counts in different year models. But I have a 90' with the 4L60 (no E) and a 241. Came stock. Don't know if this will help you. Call advance adapters and ask them. They will be able to tell you.
    Don't you buy no ugly truck!
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    YES! It is a bolt in replacement. Both 700s used 27 spline output shafts, and IF that 241 came from a 700 equipped truck, then it too has the 27 spline female input geat. The differences were if a TH400 tranny was used, in either 208 or 241 application they were 32 spline. I am in the process of figuring out if the 32 spline input gear from my junk 1985 208 case will work in a 1990 241 case...as I am throwing away the 700 tranny and replacing it with a 400 trans and need the 32 spline female gear.
    ken
  6. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    Ken, Don\'t Toss that 700!
    Ken,
    I am looking for a 700R4 builder! Don't toss it! How, when, where, and how much!
    Overdrive
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Re: Ken, Don\'t Toss that 700!
    I am in Anaheim, CA. The 700 is toasted, only has first and second gear, and is not out yet. I am so frigging sick and tired of this thing that I am finally installing what should have been in there in the first place...a TH400! This is the 6th 700 in 224,000 miles, and this Sub tows nothing!!!
    ken
  8. Overdrive
    Feb 28, 2000
    93
    Gilbert, Arizona
    Ken,
    I am in Phoenix and am looking for a 700 builder. I am not ready to slap one in but if I could pick one up for cheap I would be interested. I can wait for you to take the 700 out but how much do you want for it? I can pick it up personally since the drive from Phoenix is short!
    What kind of power do you have behind the 700? Was it rebuilt stock?
    Thanks for any info
    Overdrive
  9. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Ken, did you ever find a solution to fitting the 32 spline input into a np241?
    And Yes i dug this post up from way back.
  10. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    The 241 may have a speed sensor instead of a speedo gear. If thats the case, you'll need to get an ext. housing from an 89 or have yours modified... /forums/images/graemlins/thinking.gif
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would say that the 241 is the better 'case of the two since you can get a SYE kit for it...
  12. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Yes. The 241 and 208 input gears are NOT interchangeable. I bought a new 32 spline input for my 241 from Parts Mike. Took about 1/2 an hour to install the new input, then the transfer case bolted directly where the 208 came from (behind TH400). No more worrying about frying 700s!!! I LOVE IT!!!
  13. rugger03
    May 14, 2000
    829
    around
    Thanks Ken.
  14. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Overdrive... I'm in Mesa, I've got 2 working 700's, depending on which one I use when I swap my TBI, I'm gonna get rid of one of them... /forums/images/graemlins/deal.gif..
    Jerry...
