NP241 Burb question?
Discussion in 'The Garage' started by nm4x4, Jul 18, 2006.
  1. nm4x4
    nm4x4 1/2 ton status
    Nov 24, 2004
    144
    Wichita, Kansas (McConnell AFB)
    I have a 89 Burb and the switch in the top of the T-case is bad. I removed it and checked with a multi-meter. Is there a light on the dash that is supposed to light up when engaged? Local part stores say it is a dealer item only. Does anyone have one they want to get rid of??
    Thanks,
    Jake
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    junk yard would probbly be best bet
  3. dyeager535
    26,982
    191
    Should be able to get them from GM for around $15, the 205 switch is that way. Probably the same piece.
    Yes, the dash 4wd light should come on when in low or high 4wd.
