np241 electrical problem?
Discussion in 'The Garage' started by XHitman396, Dec 16, 2005.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so my buddy has a 94 (approx.) Z-71 with an np241 (so he says) and a nv4500 tranny. he says his four-wheel drive doesnt work because of some electrical problem. the truck is stock, and has the lever to shift into 4x4, not the button. isnt the 241 almost identical to the 208? i didnt think there was anything that important as far as electrical goes in there, all mechanical, am i wrong?? what could it be? can someone straighten this out for me?? much appreciated...
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    94 engages the front diff via a heated gas that expands and pushes a gear into place. The replacement part from GM is an electric motor that does the job much better.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As Harry said. It is the electric accuator located on the front axle. Its not a xfer case problem.
    It is a cylinder with a hex nut and wires going to it located on the front axle. Easy to replace. Just unscrew the old one and install new one $60-$90
