NP241 from Rubicon?
Discussion in 'The Garage' started by firefighter184, Dec 30, 2005.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Just wondering if the 4:1 241 from a heep Rubicon would work in my Blazer? That would be perfect. I'm not extreme enough for a doubler, nor rich enough. Thoughts anybody?
  2. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Its a round pattern, so check your adaptor, and IIRC 23 spline input. Also pricy. JB conversions can fix the input and they were selling them at one point.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    yeah i see roctracs selling for 800-1200.
    by the time you convert it, you could've had a doubler.
    or a klune-v.
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah, i doubt this is a "cheap" alternative to a doubler. Adapters and different spline counts... not good!
    As far as being "not extreme enough" for a doubler... the rocktrac has the same low gear as a doubler would. If you ain't "extreme" enough for 4x gear reduction.... stick with a standard 2.7-ish:1 geared 241. Lot cheaper that way.
    j
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I've been thinking about it too. I just need to have somebody loan me a case to tear apart and see if the input shaft will interchange with a GM one. Sorta like being able to put a 32 spline one in place of a 27 like I did when converting to a th400.
  6. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Isn't there something called a LoMax 205 that would do the job for about the same price?
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    If the lomax 205 were available yet... even then isn't it only 3:1? .3 more then a stock 241...
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Moreover, How about the SYE that the NV241J uses? Anyone check into prices to convert to a fixed yoke using Rubicon parts? :thinking:
  9. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I don't know the priced but from all I have read you can swap all the rubi 241 parts with regular 241s. I know that atleast one guy on PBB has a Rubi 241 behind a 27? spline 700r4
  10. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I just dont think I need all those gearing options and sticks that come with the doubler. Even a weekend warrior like me would always benefit from 4:1! I kinda figured the adaptors and all that would run up a prohibitive cost, I was also wondering if we could just swap guts, you know?
