np241 fye
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd-10, Feb 9, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    np241 sye
    has anyone put there sye kit in the 241? if so i need measurement for my driveline, have a 4 inch lift with 1"zero rates. would like to get the measurment before i start so i can get my driveline now thanks for any help
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    whats a fye? do you mean sye?
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    you gonna get the extreme short kit for the electronic vss?? i'm hopefully getting that soon.
  4. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    You have to measure it yourself. Not hard to do.
  5. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    i know it's not hard to do just wanted to get my driveline before i started so my truck would still be up and going.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You need to give more info if anyone is going to help you. Like someone said above, are you going to use the standard SYE or are you going to use the short version? Next are you going to run the Yoke or a Flange, which will give us the info to figure out what kind of driveline you're going to run (standard driveline or a CV driveline). This will all need to be known before anyone can help you. If you go with a CV driveline you need the pinion on the rear diff to point directly inline with the driveline, (actually about 2* downward so when under normal driving conditions it will point at the driveline as the axle will wrap some to make it be inline).
