NP241 grinding in 4-lo
Discussion in 'The Garage' started by jagerman, Mar 19, 2007.
  1. jagerman
    jagerman Registered Member
    Feb 12, 2007
    6
    here
    What causes this? It's only in 4-lo.
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Bad planetary gears?
  3. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Is it fully engaged into position? Do you shift from high to low while in gear? I once grinded my Tcase in my K5 (np208) because i left it in gear...now i always shut the engine off before shifting into low. I think N will even still cause it to grind during the shift(friction drag?). My friends is doing the same problem yours has and while im no expert i think its because hes been shifting while in gear.
    Anyone else want to back my statement up, or tell me im wrong?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if its fully engaged in 4-lo, your planetaries are toast. Easier to find a new 241 than rebuild it really.
    Engaging into 4 lo in neutral is the best way. The slight parasitic drag is just what everything needs to slide together just right.
